Linux Mint 21 Bug áudio Bluetooth
Na nova versão do Linux Mint apresenta falha no áudio com fones de ouvido Bluetooth.
Alguém apresenta este problema?
E se existe uma solução.
Imagem 01 áudio picotando
Imagem 02 sem áudio
Isso pode depender do dispositivo BT que vc usa…
Só para salientar na versão do Linux Mint 20.3 não ocorria este problema.
Segue as informaões do meu computador.
inxi -F --filter
System:
  Kernel: 5.15.0-46-generic x86_64 bits: 64 Desktop: Cinnamon 5.4.10
    Distro: Linux Mint 21 Vanessa
Machine:
  Type: Portable System: Dell product: Vostro 3550 v: N/A
    serial: <superuser required>
  Mobo: Dell model: 0XYW0C v: A12 serial: <superuser required> BIOS: Dell
    v: A12 date: 02/18/2014
Battery:
  ID-1: BAT0 charge: 32.3 Wh (100.0%) condition: 32.3/48.8 Wh (66.1%)
CPU:
  Info: dual core model: Intel Core i5-2450M bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 1523 min/max: 800/3100 cores: 1: 2584 2: 1142 3: 1374
    4: 992
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    driver: i915 v: kernel
  Device-2: Sunplus Innovation Laptop_Integrated_Webcam_FHD type: USB
    driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    v: 3.3 Mesa 22.0.5
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-46-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp5s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
  IF: wlp9s0 state: up mac: <filter>
Bluetooth:
  Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb
  Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 2.0
Drives:
  Local Storage: total: 1.01 TiB used: 263.76 GiB (25.5%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD7500BPKT-75PK4T0
  ID-3: /dev/sdc type: USB vendor: Western Digital
    model: WDS120G2G0A-00JH30 size: 111.79 GiB
Partition:
  ID-1: / size: 109.48 GiB used: 46.41 GiB (42.4%) fs: ext4 dev: /dev/sdc1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 226 Uptime: 1m Memory: 7.67 GiB used: 1017.8 MiB (13.0%)
  Shell: Bash inxi: 3.3.13
Linux Mint 21 Continua com problema no áudio com fones Bluetooth
Ninguém tem uma solução?
Tenta instalar o Pipewire no lugar do PulseAudio pra ver se resolve. Faz um backup no Timeshift primeiro pra caso aconteça algum problema você conseguir retornar o sistema pro estado anterior. Não esquece de também rodar o comando de remover o pacote pulseaudio-module-bluetooth.
Caro colega obrigado pela dica.
Mas só consegui instalar o pipewire com os seguintes comandos:
sudo add-apt-repository ppa:pipewire-debian/pipewire-upstream
sudo apt update
sudo apt install pipewire pipewire-audio-client-libraries
sudo apt install gstreamer1.0-pipewire libpipewire-0.3-{0,dev,modules} libspa-0.2-{bluetooth,dev,jack,modules} pipewire{,-{audio-client-libraries,pulse,media-session,bin,locales,tests}}
systemctl --user daemon-reload
systemctl --user --now disable pulseaudio.service pulseaudio.socket
systemctl --user --now enable pipewire pipewire-pulse
Segue a imagem de como ficou, bem diferente da anterior
Isso significa que o problema foi resolvido? Se sim, marca o post como solução. Nota que com o codec AAC a bateria do fone pode durar menos, recomendo comparar com o SBC pra ver se você realmente nota diferença na qualidade de áudio e talvez na latência.
