Fazer o gnome parar de salvar screenshots em arquivos
Sei que é uma pergunta bem besta porém não achei nenhuma resposta, alguem saberia me ajudar?
Faltou dizer qual o aplicativo… e o que você quer que ele faça, em vez de gravar.
Se for o gnome-screenshot, existem as opções -c para guardar no clipboard, -i para perguntar o que você quer.
       gnome-screenshot  [  -c ]  [ -w ]  [ -a ]  [ -b ]  [ -B ]  [ -p ]  [ -d SECONDS  ]  [ -e EFFECT  ]  [ -i ]  [ -f FILENAME
       ]  [ --display DISPLAY  ]
DESCRIPTION
       gnome-screenshot is a GNOME utility for taking screenshots of the entire screen, a window or a user-defined area  of  the
       screen.
OPTIONS
       -c, --clipboard
              Send the grab directly to the clipboard.
       -w, --window
              Grab the current active window instead of the entire screen.
       -a, --area
              Grab an area of the screen instead of the entire screen.
       -b, --include-border
              Include  the  window border within the screenshot. Note: This option is deprecated and window border is always in‐
              cluded.
       -B, --remove-border
              Remove the window border from the screenshot. Note: This option is deprecated and  window  border  is  always  in‐
              cluded.
       -p, --include-pointer
              Include the pointer with the screenshot.
       -d, --delay=SECONDS,
              Take the screenshot after the specified delay [in seconds].
       -e, --border-effect=EFFECT,
              Add  an effect to the outside of the screenshot border.  EFFECT can be ``shadow'' (adding drop shadow), ``border''
              (adding rectangular space around the screenshot), ``vintage'' (desaturating the screenshot  slightly,  tinting  it
              and adding rectangular space around it) or ``none'' (no effect).  Default is ``none''. Note: This option is depre‐
              cated and is assumed to be ``none''.
       -i, --interactive
              Interactively set options in a dialog.
       -f, --file=FILENAME
              Save screenshot directly to this file.
       --display=DISPLAY
              X display to use.
       -?, -h, --help
              Show a summary of the available options.
       In addition, the usual GTK+ command line options apply.  See the output of --help for details.
 Manual page gnome-screenshot(1) line 7/65 86% (press h for help or q to quit)
Eu estava falando sobre a ferramente de screenshot nova, quando eu tiro a captura de tela além de ir pro clipboard ele é salvo em ~/Imagens/Capturas\ de\ tela/, porém eu não consigo achar como fazer para ele ir apenas para o clipboard.
Isso é novidade do Gnome 42. Ainda não vi nada que desabilite isso - meu jeito tem sido preferir o Flameshot e/ou esvaziar a pasta periodicamente
Essa ferramenta nova eu não tenho… Posta aí o resultado de:
$ novaferramenta --help
ou
$ man novaferramenta
Também não gostei desse comportamento padrão quando usei o novo GNOME.
A maneira mais fácil de resolver é instalar o Spectacle e esquecer essa ferramenta aí…
Um jeito muito simples de se livrar da cópia física é definir o diretório onde as imagens serão salvas para o /Dev/null.
:vulcan_salute:
Infelizmente também não sei o nome da nova ferramente
Onde que muda isso?
Procurei por uma entrada no DConf para mudar isso, mas não encontrei, então, vamos no bom e velho jeitinho manual.
Abra um gerenciador de arquivos no diretório “Imagens” e renomeie a pasta “Capturas de Tela” para algum outro nome.
Depois disso, abra um terminal e crie um hardlink para o /dev/null com o mesmo nome e veja a mágica acontecer.
ln -s /dev/null "Capturas de tela "
P.s.: se não quiser guardar a pasta antiga, basta apagar ao invés de renomear.
:vulcan_salute:
Funcionou direitinho! (Provavelmente primeiro guia de como fazer isso ksks)
