ao iniciar o pc , ele me da alguns erros , sendo eles
abr 13 10:08:19 gggvv-pc kernel: usb 2-1-port4: unable to enumerate USB device
abr 13 10:08:19 gggvv-pc kernel: usb 2-1-port4: Cannot enable. Maybe the USB cable is bad?
meu pc:
System:
Kernel: 5.15.0-91-generic x86_64 bits: 64 Desktop: Cinnamon 6.0.4
Distro: Linux Mint 21.3 Virginia
Machine:
Type: Desktop System: INTEL product: N/A v: N/A
serial: <superuser required>
Mobo: INTEL model: X99-P4 v: V8.2 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 5.11 date: 03/06/2024
CPU:
Info: 12-core model: Intel Xeon E5-2650 v4 bits: 64 type: MT MCP cache:
L2: 3 MiB
Speed (MHz): avg: 1218 min/max: 1200/2900 cores: 1: 1201 2: 1200 3: 1200
4: 1200 5: 1201 6: 1201 7: 1201 8: 1202 9: 1201 10: 1202 11: 1202 12: 1201
13: 1202 14: 1200 15: 1200 16: 1200 17: 1626 18: 1200 19: 1200 20: 1200
21: 1200 22: 1200 23: 1200 24: 1201
Graphics:
Device-1: AMD Polaris 20 XL [Radeon RX 580 2048SP] driver: N/A
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: ati,vesa
unloaded: fbdev,modesetting,radeon gpu: N/A resolution: 1366x768
OpenGL: renderer: llvmpipe (LLVM 15.0.7 256 bits)
v: 4.5 Mesa 23.2.1-1ubuntu3.1~22.04.3
Audio:
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 1.83 TiB used: 113.73 GiB (6.1%)
ID-1: /dev/sda vendor: XrayDisk model: 512GB SSD size: 476.94 GiB
ID-2: /dev/sdb vendor: Seagate model: ST500LM012 HN-M500MBB
ID-3: /dev/sdc vendor: Samsung model: HD502HJ size: 465.76 GiB
ID-4: /dev/sdd vendor: Toshiba model: MQ01ABD050 size: 465.76 GiB
Partition:
ID-1: / size: 456.88 GiB used: 113.73 GiB (24.9%) fs: ext4 dev: /dev/sdb3
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 30.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 2115 fan-3: 0 fan-4: 0 fan-5: 0
Info:
Processes: 423 Uptime: 14h 1m Memory: 15.52 GiB used: 5.47 GiB (35.2%)
Shell: Bash inxi: 3.3.13
é minha primeira publicaçao , perdoem quaisquer amadorismos da minha parte , desde já agradeço a atençao (removi info do processador pra nao estourar o limite de caracteres)
mesmo sem nada na porta mencionada , o teclado que suspeito ser o culpado funciona se eu entrar em modo segurança la nas opçoes
algumas informaçoes que acho que serao uteis
lspci
00:00.0 Host bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DMI2 (rev 01)
00:01.0 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 (rev 01)
00:01.1 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 (rev 01)
00:03.0 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 3 (rev 01)
00:05.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Map/VTd_Misc/System Management (rev 01)
00:05.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO Hot Plug (rev 01)
00:05.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors (rev 01)
00:05.4 PIC: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D I/O APIC (rev 01)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 (rev 06)
00:1c.6 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 7 (rev 06)
00:1c.7 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 8 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation QM57 Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Polaris 20 XL [Radeon RX 580 2048SP] (rev ef)
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 476,9G 0 disk
└─sda1 8:1 0 476,8G 0 part
sdb 8:16 0 465,8G 0 disk
└─sdb3 8:19 0 465,3G 0 part /
sdc 8:32 0 465,8G 0 disk
├─sdc1 8:33 0 465,8G 0 part
└─sdc2 8:34 0 1M 0 part
sdd 8:48 0 465,8G 0 disk
├─sdd1 8:49 0 100M 0 part
└─sdd3 8:51 0 465,5G 0 part
lsusb
Bus 002 Device 007: ID 0318:2808 2.4G Composite Devic
Bus 002 Device 008: ID 046d:c07f Logitech, Inc. Gaming Mouse G302
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 1a2c:2c27 China Resource Semico Co., Ltd USB Keyboard
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo dmidecode
