Erro no meu arquivo.spec
Aparece o seguinte erro no meu arquivo.spec:
[junior@localhost ~]$ rpmbuild -bb .spec
Executando (%prep): /bin/sh -e /var/tmp/rpm-tmp.Iy3GGy
+ umask 022
+ cd /home/junior/rpmbuild/BUILD
+ RPM_EC=0
++ jobs -p
+ exit 0
Executando (%install): /bin/sh -e /var/tmp/rpm-tmp.b80d7A
+ umask 022
+ '[' /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64 '!=' / ']'
+ rm -rf /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64
++ dirname /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64
+ mkdir -p /home/junior/rpmbuild/BUILDROOT
+ mkdir /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64
+ mkdir -p /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64//usr/bin/
+ install -m75 /home/junior/rpmbuild/BUILD/CalculadoraCompleta /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64//usr/bin
+ mkdir -p /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64//usr/share/pixmaps/
+ mkdir -p /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64//usr/share/applications/
+ install -m644 /home/junior/rpmbuild/SOURCES/CalculadoraCompleta.desktop -D /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64/usr/share/applications/
+ install -m644 /home/junior/rpmbuild/SOURCES/CalculadoraCompleta.desktop -D /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64/usr/share/pixmaps
+ /usr/lib/rpm/check-buildroot
grep: /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64/usr/bin/CalculadoraCompleta: Permission denied
+ /usr/lib/rpm/redhat/brp-ldconfig
+ /usr/lib/rpm/brp-compress
+ /usr/lib/rpm/brp-strip /usr/bin/strip
+ /usr/lib/rpm/brp-strip-comment-note /usr/bin/strip /usr/bin/objdump
+ /usr/lib/rpm/brp-strip-static-archive /usr/bin/strip
+ /usr/lib/rpm/redhat/brp-python-bytecompile /usr/bin/python 1 0
+ /usr/lib/rpm/brp-python-hardlink
+ /usr/lib/rpm/redhat/brp-mangle-shebangs
Procurando por arquivos desempacotados: /usr/lib/rpm/check-files /home/junior/rpmbuild/BUILDROOT/CalculadoraCompleta-1.0-1.x86_64
Executando (%clean): /bin/sh -e /var/tmp/rpm-tmp.cwxSFC
+ umask 022
+ RPM_EC=0
++ jobs -p
+ exit 0
Como está meu arquivo.spec:
Summary:CalculadoraCompleta
Version:1.0
Release:1
License:GPLv3
Group:Office
Source0:CalculadoraCompleta.tar.gz
Source1:CalculadoraCompleta.desktop
URL:ftp://ftp.whitehat.forumbrasil.net
Vendor:Joao Santos Vieira Junior
Packager: ftp:<ftp@whitehat.forumbrasil.net>
%description
Calculadora Completa feita no Lazarus(Delphi 7 para Linux)
%prep
%install
mkdir -p $RPM_BUILD_ROOT/%{_bindir}/
install -m75 $RPM_BUILD_DIR/CalculadoraCompleta $RPM_BUILD_ROOT/%{_bindir}
mkdir -p $RPM_BUILD_ROOT/%{_datadir}/pixmaps/
mkdir -p $RPM_BUILD_ROOT/%{_datadir}/applications/
install -m644 %{SOURCE1} -D $RPM_BUILD_ROOT/usr/share/applications/
install -m644 %{SOURCE1} -D $RPM_BUILD_ROOT/usr/share/pixmaps
%clean
rm -rf $RPM_BUILD_ROOT
%post
%{update_menus}
%defattr(-,root,root,0755)
/usr/share/applications/CalculadoraCompleta.desktop
/usr/share/pixmaps/CalculadoraCompleta.png
Perceba que tem uma linha dizendo:
Permission Denied(Permissão negada),gostaria de saber porque está dando isso,e como resolve-la?
Já tentou rodar como root ?
Já,dá outro erro semelhante.
Qual é o padrão de permissão para os demais diretórios do sistema? É que eu alterei a permissão do diretório /lib/rpm/check-files
Esse erro é padrão na minha compilação do arquivo.spec:
Executando (%prep): /bin/sh -e /var/tmp/rpm-tmp.JlIJzT
+ umask 022
+ RPM_EC=0
++ jobs -p
+ exit 0
Executando (%install): /bin/sh -e /var/tmp/rpm-tmp.7KxKvR
+ umask 022
erro: Arquivo(s) instalado(s) (mas não empacotado(s)) encontrado(s):
   /usr/share/pixmaps/CalculadoraCompleta.desktop
Erros na construção do RPM:
Alguém pode me ajudar?
