Erro ao tentar usar criptografia GPG no sistema de carteiras KDE
Eu utilizo o Arch linux com o KDE, e sempre que inicio o sistema pede pra selecionar no sistema de carteiras do KDE o tipo de criptografia, ao optar pela que aparentemente é a mais segura recebo o erro que aparece na imagem, dizendo que meu sistema não tem chaves adequadas para criptografia. Alguém sabe como resolver? Agradeço de coração a quem puder me ajudar.
https://wiki.archlinux.org/index.php/KDE#Problems_with_saving_credentials_and_persistently_occurring_KWallet_dialogs
Problems with saving credentials and persistently occurring KWallet dialogs
It is not recommended to turn off the KWallet password saving system in the user settings as it is required to save encrypted credentials like WiFi passphrases for each user. Persistently occuring KWallet dialogs can be the consequence of turning it off.
In case you find the dialogs to unlock the wallet annoying when applications want to access it, you can let the display managers SDDM and LightDM unlock the wallet at login automatically, see KDE Wallet#Unlock KDE Wallet automatically on login. The first wallet needs to be generated by KWallet (and not user-generated) in order to be usable for system program credentials.
In case you want the wallet credentials not to be opened in memory for every application, you can restrict applications from accessing it with kwalletmanager in the KWallet settings.
If you do not care for credential encryption at all, you can simply leave the password forms blank when KWallet asks for the password while creating a wallet. In this case, applications can access passwords without having to unlock the wallet first.
Em português
https://wiki.archlinux.org/index.php/KDE_(Português)#Problemas_com_salvar_credenciais_e_ocorrendo_persistentemente_diálogos_do_KWallet
Problemas com salvar credenciais e ocorrendo persistentemente diálogos do KWallet
Não é recomendado desativar o sistema de salvamento de senhas do KWallet nas configurações do usuário, pois é necessário para salvar credenciais criptografadas, como senhas WiFi para cada usuário. Diálogos do KWallet aparecendo de forma persistente podem ser a consequência de desativá-lo.
Caso você ache irritantes os diálogos para desbloquear a carteira quando os aplicativos quiserem acessá-la, você pode deixar que os gerenciadores de exibição SDDM e LightDM desbloqueiem a carteira no início da sessão automaticamente, consulte KDE Wallet#Unlock KDE Wallet automatically on login. A primeira carteira precisa ser gerada pelo KWallet (e não gerada pelo usuário) para ser usada nas credenciais do programa do sistema.
Caso você queira que as credenciais da carteira não sejam abertas na memória para cada aplicativo, você pode restringir os aplicativos de acessá-los com o kwalletmanager nas configurações do KWallet.
Se você não se importa com a criptografia de credenciais, pode simplesmente deixar os formulários de senha em branco quando o KWallet solicitar a senha durante a criação de uma carteira. Nesse caso, os aplicativos podem acessar senhas sem ter que desbloquear a carteira primeiro.
