Erro ao instalar arquivo.bin (JAVA)
Boa Noite gente!
Ao tentar instalar um arquivo .bin utilizando o comando ./MapManInst.bin recebo a seguinte mensagem de erro no terminal:
vinicius@vinicius-Lenovo-ideapad-310-15ISK:~/Downloads$ ./MapManInst.bin
Preparing to install…
Extracting the JRE from the installer archive…
Unpacking the JRE…
Extracting the installation resources from the installer archive…
Configuring the installer for this system’s environment…
strings: ‘/lib/libc.so.6’: No such file
Launching installer…
Graphical installers are not supported by the VM. The console mode will be used instead…
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.UnsatisfiedLinkError: /tmp/install.dir.2338/Linux/resource/jre/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at sun.security.action.LoadLibraryAction.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.NativeLibLoader.loadLibraries(Unknown Source)
at sun.awt.DebugHelper.(Unknown Source)
at java.awt.Component.(Unknown Source)
at com.zerog.ia.installer.util.BidiUtilImpl.setDefaultLocale(DashoA10*…)
at ZeroGbb.a(DashoA10*…)
at com.zerog.ia.installer.LifeCycleManager.q(DashoA10*…)
at com.zerog.ia.installer.LifeCycleManager.b(DashoA10*…)
at com.zerog.ia.installer.LifeCycleManager.a(DashoA10*…)
at com.zerog.ia.installer.Main.main(DashoA10*…)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(DashoA10*…)
at com.zerog.lax.LAX.main(DashoA10*…)
This Application has Unexpectedly Quit: Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Utilizando o comando java -version tenho como retorno:
openjdk version “10.0.2” 2018-07-17
OpenJDK Runtime Environment (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4)
OpenJDK 64-Bit Server VM (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4, mixed mode)
Já rodei a internet inteira procurando uma solução mas nao achei nada que pudesse ajudar a resolver isso. Se alguém puder ajudar ou tiver alguma ideia do que fazer, ficaria extremamente grato.
Captura%20de%20tela%20de%202019-04-10%2020-29-33
se eu não em engano o java já esta instalado por padrão nessa distro quando vc digita o comando java-version já mostra a versão que esta instalado no caso
tem umas distros que não vem com isso.
sobre o erro que ta dando ao instalar o arquivo .bin vc ta executando o comado sudo chmod +x nele ? e depois sudo ./ nele ?
Eu só tava usando o sudo ./
Tentei fazer agr como vc falou mas retornou o mesmo erro
de onde vc baixo esse arquivo .bin recomendo vc ir pro site oficial do Java https://www.java.com/pt_BR/download/ la ter as versões e as Instruções pra vc instalar os arquivos do site oficial ta vindo em .tar
Vinicius, você já tentou esta solução do Stack Overflow?
Não vou afirmar que o OpenJDK é problemático, mas eu sempre tenho problemas quando tento usar. Tentaria instalar o JRE da Oracle no lugar, caso ainda não funcione.
Deu certo aqui!!!
Muito obrigado
Marque a resposta como solução para ajudar quem tenha o mesmo problema no futuro.
