Easycamera reconhecida mas imagem continua preta - ideapad 3030
Boa noite, tenho um Ideapad 330 i5 com webcam integrada Easycamera e não consigo sair da tela preta por nada. No skype, kamoso, cheese e VLC a luz acende mas sem nenhuma imagem :confused: Já cheguei até em forums da frança e nada do que tentei funcionou. Se alguém souber eu mando um sorvete de ifood uahuahuah.
Segue o necessário (acho) uname -sr Linux 5.9.0-1-amd64
dmesg | grep uvcvideo
[ 26.818012] uvcvideo: Found UVC 1.00 device EasyCamera (174f:241a)
[ 26.826718] uvcvideo 1-8:1.0: Entity type for entity Extension 3 was not initialized!
[ 26.826721] uvcvideo 1-8:1.0: Entity type for entity Processing 2 was not initialized!
[ 26.826722] uvcvideo 1-8:1.0: Entity type for entity Camera 1 was not initialized!
[ 26.827008] usbcore: registered new interface driver uvcvideo
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 174f:241a Syntek EasyCamera
Bus 001 Device 003: ID 8087:0a2a Intel Corp. Bluetooth wireless interface
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ls -l /dev/video0
crw-rw----+ 1 root video 81, 0 nov 2 18:40 /dev/video0
inxi -Fxzd
System:
Kernel: 5.9.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME 3.38.1 Distro: Debian GNU/Linux bullseye/sid
Machine:
Type: Laptop System: LENOVO product: 81FE v: Lenovo ideapad 330-15IKB
serial:
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: UEFI: LENOVO
v: 8TCN51WW date: 12/08/2018
Battery:
ID-1: BAT0 charge: 14.0 Wh condition: 23.4/30.0 Wh (78%)
model: LGC L16L2PB2 status: Discharging
CPU:
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 28800
Speed: 734 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 700
3: 700 4: 700 5: 701 6: 701 7: 700 8: 700
Graphics:
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0
Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus ID: 1-8:4
Display: x11 server: X.Org 1.20.9 driver: modesetting
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 20.2.1 direct render: Yes
Audio:
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.9.0-1-amd64
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
IF: enp1s0 state: down mac:
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 3000 bus ID: 02:00.0
IF: wlp2s0 state: up mac:
Drives:
Local Storage: total: 931.51 GiB used: 334.74 GiB (35.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-24Z10T0
size: 931.51 GiB temp: 42 C
Message: No Optical or Floppy data was found.
Partition:
ID-1: / size: 905.86 GiB used: 334.44 GiB (36.9%) fs: ext4 dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 5.00 GiB used: 304.6 MiB (5.9%)
dev: /dev/sda2
Sensors:
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 252 Uptime: 2h 39m Memory: 3.76 GiB used: 1.83 GiB (48.7%)
Init: systemd runlevel: 5 Compilers: gcc: 10.2.0 Packages: 3079
Shell: Bash v: 5.1.0-rc1 inxi: 3.1.08
v4l2-ctl --info --device /dev/video1
Driver Info:
Driver name : uvcvideo
Card type : EasyCamera: EasyCamera
Bus info : usb-0000:00:14.0-8
Driver version : 5.9.1
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04a00000
Metadata Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : EasyCamera: EasyCamera
Serial :
Media version : 5.9.1
Hardware revision: 0x00000013 (19)
Interface Info:
Type : V4L Video
Entity Info:
Name : EasyCamera: EasyCamera
Function : V4L2 I/O
[email protected]:/home/anneaf#
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
02:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3165 Plus Bluetooth (rev 99)
v4l2-ctl -d /dev/video0 --list-ctrls
brightness 0x00980900 (int) : min=0 max=100 step=1 default=50 value=50
contrast 0x00980901 (int) : min=0 max=100 step=1 default=50 value=50
saturation 0x00980902 (int) : min=0 max=100 step=1 default=50 value=50
hue 0x00980903 (int) : min=0 max=100 step=1 default=50 value=50
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gamma 0x00980910 (int) : min=0 max=100 step=1 default=50 value=50
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1
white_balance_temperature 0x0098091a (int) : min=2500 max=6500 step=1 default=4500 value=4500 flags=inactive
sharpness 0x0098091b (int) : min=0 max=100 step=1 default=50 value=50
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
privacy 0x009a0910 (bool) : default=0 value=0
lsmod
Module Size Used by
rfcomm 90112 4
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 86016 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
fuse 143360 3
ctr 16384 2
ccm 20480 6
cmac 16384 6
algif_hash 16384 3
algif_skcipher 16384 3
af_alg 32768 14 algif_hash,algif_skcipher
bnep 28672 2
cpufreq_powersave 20480 0
cpufreq_conservative 16384 0
cpufreq_userspace 20480 0
binfmt_misc 24576 1
nls_ascii 16384 1
nls_cp437 20480 1
vfat 20480 1
fat 86016 1 vfat
uvcvideo 114688 0
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 32768 1 uvcvideo
videobuf2_common 61440 2 videobuf2_v4l2,uvcvideo
videodev 278528 3 videobuf2_v4l2,uvcvideo,videobuf2_common
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
btusb 61440 0
intel_rapl_msr 20480 0
intel_rapl_common 32768 1 intel_rapl_msr
btrtl 24576 1 btusb
btbcm 20480 1 btusb
btintel 32768 1 btusb
bluetooth 729088 33 btrtl,btintel,btbcm,bnep,btusb,rfcomm
intel_pmc_core_pltdrv 16384 0
intel_pmc_core 45056 0
jitterentropy_rng 16384 1
x86_pkg_temp_thermal 20480 0
intel_powerclamp 20480 0
coretemp 20480 0
drbg 28672 1
ansi_cprng 16384 0
kvm_intel 319488 0
ecdh_generic 16384 1 bluetooth
ecc 36864 1 ecdh_generic
kvm 831488 1 kvm_intel
snd_soc_skl 180224 0
iwlmvm 327680 0
irqbypass 16384 1 kvm
ghash_clmulni_intel 16384 0
snd_soc_hdac_hda 24576 1 snd_soc_skl
mac80211 917504 1 iwlmvm
snd_hda_codec_hdmi 73728 1
mei_me 45056 0
snd_hda_ext_core 36864 2 snd_soc_hdac_hda,snd_soc_skl
aesni_intel 372736 13
sg 36864 0
snd_hda_codec_generic 98304 1
snd_soc_sst_ipc 20480 1 snd_soc_skl
serio_raw 20480 0
snd_soc_sst_dsp 40960 1 snd_soc_skl
libarc4 16384 1 mac80211
snd_soc_acpi_intel_match 45056 1 snd_soc_skl
libaes 16384 2 bluetooth,aesni_intel
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_soc_skl
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_soc_core 315392 2 snd_soc_hdac_hda,snd_soc_skl
crypto_simd 16384 1 aesni_intel
snd_compress 32768 1 snd_soc_core
snd_hda_intel 57344 3
snd_intel_dspcfg 24576 2 snd_hda_intel,snd_soc_skl
snd_hda_codec 163840 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_soc_hdac_hda
snd_hda_core 106496 7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 135168 7 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core
iwlwifi 290816 1 iwlmvm
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
cryptd 24576 5 crypto_simd,ghash_clmulni_intel
intel_xhci_usb_role_switch 16384 0
roles 16384 1 intel_xhci_usb_role_switch
cfg80211 897024 3 iwlmvm,iwlwifi,mac80211
mei 126976 1 mei_me
snd 110592 19 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
soundcore 16384 1 snd
ideapad_laptop 24576 0
joydev 28672 0
sparse_keymap 16384 1 ideapad_laptop
glue_helper 16384 1 aesni_intel
rfkill 28672 9 bluetooth,ideapad_laptop,cfg80211
intel_pch_thermal 16384 0
evdev 28672 10
rapl 16384 0
tpm_crb 20480 0
intel_cstate 20480 0
intel_uncore 167936 0
tpm_tis 16384 0
tpm_tis_core 28672 1 tpm_tis
tpm 73728 3 tpm_tis,tpm_crb,tpm_tis_core
efi_pstore 16384 0
pcspkr 16384 0
efivars 20480 1 efi_pstore
rng_core 16384 1 tpm
acpi_pad 28672 0
ac 16384 0
wmi_bmof 16384 0
intel_wmi_thunderbolt 20480 0
squashfs 65536 9
loop 36864 18
parport_pc 40960 0
ppdev 24576 0
lp 20480 0
parport 69632 3 parport_pc,lp,ppdev
efivarfs 16384 1
ip_tables 28672 0
x_tables 53248 1 ip_tables
autofs4 53248 2
ext4 798720 1
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 139264 1 ext4
crc32c_generic 16384 0
usbhid 65536 0
hid_rmi 24576 0
sd_mod 61440 4
rmi_core 86016 1 hid_rmi
t10_pi 16384 1 sd_mod
crc_t10dif 20480 1 t10_pi
crct10dif_generic 16384 0
hid_generic 16384 0
i915 2658304 21
i2c_algo_bit 16384 1 i915
drm_kms_helper 262144 1 i915
ahci 40960 3
libahci 45056 1 ahci
cec 49152 2 drm_kms_helper,i915
xhci_pci 20480 0
r8169 98304 0
xhci_hcd 286720 1 xhci_pci
libata 290816 2 libahci,ahci
realtek 24576 1
drm 614400 6 drm_kms_helper,i915
crct10dif_pclmul 16384 1
mdio_devres 16384 1 r8169
usbcore 323584 5 xhci_hcd,usbhid,uvcvideo,btusb,xhci_pci
crct10dif_common 16384 3 crct10dif_generic,crc_t10dif,crct10dif_pclmul
libphy 151552 3 r8169,mdio_devres,realtek
crc32_pclmul 16384 0
scsi_mod 258048 3 sd_mod,libata,sg
crc32c_intel 24576 2
i2c_i801 32768 0
i2c_hid 32768 0
i2c_smbus 20480 1 i2c_i801
intel_lpss_pci 24576 0
hid 147456 4 i2c_hid,usbhid,hid_generic,hid_rmi
intel_lpss 16384 1 intel_lpss_pci
usb_common 16384 3 xhci_hcd,usbcore,uvcvideo
idma64 20480 0
wmi 36864 3 intel_wmi_thunderbolt,wmi_bmof,ideapad_laptop
button 24576 0
battery 20480 0
video 53248 2 ideapad_laptop,i915
Faltou uma amostra de DNA e também o CPF / RG. :wink:
:vulcan_salute:t2:
e nem assim consigo :frowning:
Olá @anne tudo beleza?
Brincadeiras à parte, parece que essa câmera é meio “complicada” encontrei muitos relatos de problemas com ela, seja no Windows ou no Linux. Como você está usando Debian, minha primeira recomendação é que você ative os repositórios “non-free” e tente instalar os firmwares que podem ser relativos a esse modelo de webcam.
Nesta discussão, um usuário recomenda instalar alguns pacotes para outro modelo de Lenovo em uma situação similar.
sudo apt-get install libsbigudrv2 libsbigudrv0
Serão necessários alguns testes para identificar o pacote de firmwares mais adequado. Neste vídeo aqui, o autor cita a necessidade de ativar a câmera com “FN+F8”, você já testou isso?
:vulcan_salute:t2:
Bastante complicada mesmo, já testei todos os FN pra ter certeza, chequei privacidade, atualizei kernel, baixei tanto pacote V4L que nem lembro quantos, imensidão de posts tbm :frowning: inclusive esse ASK que vc mandou… nada funciona. To achando que vou precisar levar em algum lugar mesmo, preciso de Skype pra trampar. Muito obrigada pela disposição de ajudar
Você já testou com um live pendrive de outra distribuição para ver se funciona? Tipo o Pop!OS ou um Ubuntu mais recente?
Esse teste é interessante porque se funcionar, eliminamos a possibilidade de ser hardware. E também podemos ver qual é o driver que está carregado nesta distribuição para poder ver se está disponível no Debian.
:vulcan_salute:t2:
Não fiz isso não, nunca fiz algo parecido por sinal. Vou pesquisar como faz e tentar!
É bastante simples:
  1. faça ou download da ISO do sistema - Pop / Ubuntu
  2. Instale o programa PopSicle (flatpak) pela loja
  3. Grave a ISO no pendrive usando o PopSicle.
Dê boot pelo pendrive de acordo com as instruções da Bios do seu notebook, geralmente basta apertar F8 ou F12, depende do modelo.
:vulcan_salute:t2:
Levei p um amigo fazer p mim eqto fui trabalhar, tbm não funcionou :frowning: pior que a garantia era de um ano só… foi em junho. To na roça
Eae @anne tudo bem?? Só por desencargo mesmo tenta o Ubuntu, pode ser o 20.04 ou 20.10, tenho um vídeo ensinando como criar um pendrive bootavel e tbm de como formatar com o Ubuntu. Se mesmo assim não funfa, pode ser alguma coisa no hardware ou vc pode tenta a instalação do Windows e vê se funciona (tenho um vídeo falando sobre como ter o Win10 de forma legal e tudo mais), espero que ajude :wink: !!!
