Consegui instalar o gentoo no virtualbox,só falta instalar o KDE-plasma
Consegui instalar o gentoo com a ajuda de vocês,estou nessa tela no VirtualBox tentando instalar o KDE-Plasma,entre outras coisas:
O que faço agora? Não instalei ainda o KDE-Plasma e o wpa_supplicant.
Mudou o profile para uma opção com o Plasma?
rod@gentoo ~ $ eselect profile list
Available profile symlink targets:
  [1]   default/linux/amd64/17.0 (stable)
  [2]   default/linux/amd64/17.0/selinux (stable)
  [3]   default/linux/amd64/17.0/hardened (stable)
  [4]   default/linux/amd64/17.0/hardened/selinux (stable)
  [5]   default/linux/amd64/17.0/desktop (stable)
  [6]   default/linux/amd64/17.0/desktop/gnome (stable)
  [7]   default/linux/amd64/17.0/desktop/gnome/systemd (stable)
  [8]   default/linux/amd64/17.0/desktop/plasma (stable)
  [9]   default/linux/amd64/17.0/desktop/plasma/systemd (stable)
  [10]  default/linux/amd64/17.0/developer (stable)
  [11]  default/linux/amd64/17.0/no-multilib (stable)
  [12]  default/linux/amd64/17.0/no-multilib/hardened (stable)
  [13]  default/linux/amd64/17.0/no-multilib/hardened/selinux (stable)
  [14]  default/linux/amd64/17.0/systemd (stable)
  [15]  default/linux/amd64/17.0/x32 (dev)
  [16]  default/linux/amd64/17.1 (stable)
  [17]  default/linux/amd64/17.1/selinux (stable)
  [18]  default/linux/amd64/17.1/hardened (stable)
  [19]  default/linux/amd64/17.1/hardened/selinux (stable)
  [20]  default/linux/amd64/17.1/desktop (stable)
  [21]  default/linux/amd64/17.1/desktop/gnome (stable)
  [22]  default/linux/amd64/17.1/desktop/gnome/systemd (stable)
  [23]  default/linux/amd64/17.1/desktop/plasma (stable) *
  [24]  default/linux/amd64/17.1/desktop/plasma/systemd (stable)
  [25]  default/linux/amd64/17.1/developer (stable)
  [26]  default/linux/amd64/17.1/no-multilib (stable)
  [27]  default/linux/amd64/17.1/no-multilib/hardened (stable)
  [28]  default/linux/amd64/17.1/no-multilib/hardened/selinux (stable)
  [29]  default/linux/amd64/17.1/systemd (stable)
  [30]  default/linux/amd64/17.0/musl (exp)
  [31]  default/linux/amd64/17.0/musl/hardened (exp)
  [32]  default/linux/amd64/17.0/musl/hardened/selinux (exp)
  [33]  default/linux/amd64/17.0/uclibc (exp)
  [34]  default/linux/amd64/17.0/uclibc/hardened (exp)
Note o meu está com o asterisco na opção 23. Conforme voce quiser systemd ou openrc, selecione 23 ou 24.
eselect profile set XX
Depois compile novamente os pacotes com todas as alterações das use-flags do novo profile.
emerge --update --deep --newuse -av @world
Recomendo reiniciar o computador pois deve haver muitas alterações. Daí já dá para instalar o kde basicão!
emerge -av kde-plasma/plasma-meta
Se bem me lembro é isso, já deve puxar o sddm e pronto para adicionar os programas do kde que você mais usa.
No final não esqueça de remover os pacotes não necessários
emerge --depclean -a
1 Curtida
