Fala camaradas, tudo bem? Estou tentando compartilhar tela no discord, a tela é compartilhada normalmente mas o áudio não funciona, somente o microfone funciona. O problema é ocorro em outros programas como Skype e Zoom. Estou deixando aqui todas as informações do meu sistema, talvez possa ajudar.
$ inxi -Fxz
System:
Host: manjaro Kernel: 5.4.35-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 9.3.0 Desktop: Gnome 3.36.1 Distro: Manjaro Linux
Machine:
Type: Desktop Mobo: PCWARE model: IPMH81G1 serial: <filter>
BIOS: American Megatrends v: F5 DB date: 03/20/2014
CPU:
Topology: Dual Core model: Intel Pentium G3250 bits: 64 type: MCP
arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12774
Speed: 1181 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 1226 2: 1035
Graphics:
Device-1: NVIDIA GF119 [GeForce GT 610] vendor: ZOTAC driver: nvidia
v: 390.132 bus ID: 01:00.0
Display: x11 server: X.org 1.20.8 driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GT 610/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132
direct render: Yes
Audio:
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Realtek
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GF119 HDMI Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.35-1-MANJARO
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel port: d000 bus ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 465.76 GiB used: 39.72 GiB (8.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
Partition:
ID-1: / size: 47.64 GiB used: 26.06 GiB (54.7%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 409.55 GiB used: 13.66 GiB (3.3%) fs: ext4
dev: /dev/sda2
Sensors:
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info:
Processes: 221 Uptime: 9h 49m Memory: 3.80 GiB used: 2.42 GiB (63.8%)
Init: systemd Compilers: gcc: 9.3.0 Shell: zsh v: 5.8 inxi: 3.0.37
