Como solucionar o problema do xdg-open no Debian 12?
Quando utilizo o xdg-open para abrir algo, recebo essa mensagem no terminal:
almir@almir-Aspire-E5-573G:~$ xdg-open /home/almir/Documentos/
QSocketNotifier: Can only be used with threads started with QThread
almir@almir-Aspire-E5-573G:~$ QSocketNotifier: Can only be used with threads started with QThread
Por que ocorre isso e como resolver?
inxi -b
  Host: almir-Aspire-E5-573G Kernel: 6.1.0-27-amd64 arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.5 Distro: Debian GNU/Linux 12 (bookworm)
Machine:
  Type: Laptop System: Acer product: Aspire E5-573G v: V3.72
    serial: <superuser required>
  Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
    serial: <superuser required> UEFI: Insyde v: 1.25 date: 07/15/2015
Battery:
  ID-1: BAT1 charge: 0% condition: 12.9/N/A Wh volts: 2.1 min: 14.8
CPU:
  Info: dual core Intel Core i5-5200U [MT MCP] speed (MHz): avg: 1025
    min/max: 500/2700
Graphics:
  Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
  Device-2: NVIDIA GK208BM [GeForce 920M] driver: nouveau v: kernel
  Device-3: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
  Display: wayland server: X.Org v: 1.22.1.9 with: Xwayland v: 22.1.9
    compositor: kwin_wayland driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: iris gpu: i915 resolution: 1366x768~60Hz
  API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 5500 (BDW
    GT2)
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    driver: ath9k
Drives:
  Local Storage: total: 111.79 GiB used: 35.77 GiB (32.0%)
Info:
  Processes: 221 Uptime: 2h 48m Memory: 7.67 GiB used: 4.61 GiB (60.0%)
  Shell: Bash inxi: 3.3.26
Você está tentando abrir um diretório (~/Documentos) pelo terminal.
Tente adicionar o dolphin, do KDE, como aplicação padrão para abrir diretórios no seu mimelist:
xdg-mime default org.kde.dolphin.desktop inode/directory
Tente novamente com o mesmo comando.
Espero que ajude.
Não alcancei o resultado. Consigo abrir e utilizar o aplicativo porém meu problema é abrir através do terminal.
Você quer abrir o diretório como na imagem abaixo:
Se for você precisa de um programa que funcione no terminal como o ranger, o dolphin é um programa gráfico.
Olá @spec, tudo bem contigo?
Caso você tenha feito uma instalação customizada do Debian, confira se os pacotes do XDG estão instalados. Esse sintoma que você está relatando possivelmente é devido a falta de algum deles:
xdg-desktop-portal xdg-utils xdg-dbus-proxy
:vulcan_salute:
Olá Eddie, obrigado por comentar em meu tópico. Utilizei o processo básico de instalação através dos pacotes e notei que todos estão instalados e não inseri em minha máquina uma versão customizada do Debian pois foge do meu alcance no conhecimento do GNU Linux.
