Eu tenho uma dúvida aqui. O meu notebook possui uma alavanca na parte da frente que, em teoria, liga e desliga a conexão bluetooth. Na barra de notificação, existe o ícone do bluetooth, mas ele não detecta nenhum dispositivo bluetooth instalado. Como posso descobrir se meu notebook realmente tem bluetooth ou não e, caso ele tenha, fazer ele funcionar?
Resposta ao lspci:
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M-E LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
01:00.0 Ethernet controller: Qualcomm Atheros AR8131 Gigabit Ethernet (rev c0)
02:00.0 Network controller: Intel Corporation Centrino Wireless-N 1000 [Condor Peak]
Resposta ao lsusb:
Bus 002 Device 002: ID 064e:a102 Suyin Corp. Acer/Lenovo Webcam [CN0316]
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Primeiro, verifica se o BT está ativo, vendo o led indicativo e fuçando na BIOS (de repente tem algo ali). Pode ser algo relacionado ao kernel, já que o Zorin 15 usa um mais antigo. Faz um pendrive com Manjaro (o kernel é mais recente) e testa pra ver se funciona. Se sim, migre de distro ou tente instalar um kernel mais recente nele (ou ainda aguarde pelo novo Zorin, não deve demorar muito e podem ter corrigido o problema)
Uma ideia é pesquisar “bluetooth issues qualcomm atheros zorin 15 ubuntu 18.04” e ver o que aparece nos motores de busca
Tudo bem, então. Não é um problema urgente de qualquer maneira, já que eu normalmente uso o Google Drive para transferir arquivos entre esse notebook e o celular.
Duas boas soluções para transferir arquivos entre celular e PC são o KDE Connect e o Warpinator - estando os dois no mesmo WiFi, são muito mais rápidos que BT
