Conheça o Anbox, a melhor forma de rodar aplicativos Android no PC!
Veja como instalar o Anbox e instale diversos aplicativo do Android no seu Linux!
Baita gambiarra frustrante esse Anbox, ainda é muito experimental.
@vanderlei_ventura2 estou pelejando com esse cara aí… Estou com problemas com “binder=false”
sou “Básico” aqui, vou precisar de ajuda pra resolver.
segue dados:
anbox.appmgr
[ 2021-08-03 12:19:53] [launch.cpp:168@operator()] Session manager is not yet running, trying to start it
[ 2021-08-03 12:19:53] [launch.cpp:117@launch_session_manager] Started session manager, will now try to connect …
[ 2021-08-03 12:19:53] [splash_screen.cpp:55@SplashScreen] Window has no associated renderer yet, creating one …
[ 2021-08-03 12:20:43] [daemon.cpp:61@Run] [org.freedesktop.DBus.Error.ServiceUnknown] The name org.anbox was not provided by any .service files
anbox system-info:
version: local-ad377ff
snap-revision: 213
cpu:
arch: x86
brand: Intel(R) Core™ i5-3210M CPU @ 2.50GHz
features:
Desde já agradeço pelo tempo de todos.
