Então galera, instalei o Manjaro Gnome em uma máquina e grande parte do sistema está em inglês, alguém faz ideia de como trocar? Quando vou em regiões e idiomas, e clico em “Language”. não aparece nada. Vou deixar meu inxi -Fxz logo abaixo.
inxi -Fxz
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_COLLATE = "C",
LANG = "pt_BR.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
System:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.3 Distro: Manjaro Linux
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2006 date: 11/13/2019
CPU:
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 81469
Speed: 3017 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 3017 2: 1404 3: 1429 4: 1436 5: 1370 6: 2721 7: 1331 8: 1324 9: 2312
10: 1348 11: 1353 12: 1957
Graphics:
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus ID: 08:00.0
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root
resolution: <missing: xdpyinfo>
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio:
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.3
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 447.13 GiB used: 9.36 GiB (2.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
Partition:
ID-1: / size: 48.97 GiB used: 7.6 GiB (15.5%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 269.5 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 389.64 GiB used: 1.77 GiB (0.5%) fs: ext4 dev: /dev/sda3
Swap:
Alert: No Swap data was found.
Sensors:
System Temperatures: cpu: 53.8 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1124
Info:
Processes: 314 Uptime: 17m Memory: 15.63 GiB used: 1.96 GiB (12.6%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1112
Shell: Zsh v: 5.8 inxi: 3.3.01
