Bom dia Pessoal,
instalei o manjaro no meu notebook um dell inspiron 3442 e ele possui aquelas placas hibridas de video uma Mesa Intel(R) HD Graphics 4400 (HSW GT2) e uma NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]. acontece que ja tentei instalar todos os drivers possiveis e não consigo utilizar a placa nvidia. o computador parece uma carroça. (i5 4 geração com 8gb de memória e um ssd). segue algumas informações:
yay -Q | grep nvidia ✔
lib32-nvidia-390xx-utils 390.157-4
linux515-nvidia-390xx 390.157-35
linux61-nvidia-390xx 390.157-31
mhwd-nvidia 530.41.03-4
mhwd-nvidia-390xx 390.157-6
mhwd-nvidia-470xx 470.182.03-2
nvidia-390xx-settings 390.157-4
nvidia-390xx-utils 390.157-6
nvidia-prime 1.0-4
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2023.03.23 false PCI
Warning: No installed USB configs!
glxinfo | grep 'renderer string'
OpenGL renderer string: Mesa Intel(R) HD Graphics 4400 (HSW GT2)
prime-run glxinfo | grep 'renderer string'
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 150 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 39
Current serial number in output stream: 40
inxi -G
Graphics:
Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M] driver: N/A
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell v: 43.5 driver: gpu: i915 resolution: 1366x768~60Hz
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 4400 (HSW
GT2)
System:
Kernel: 5.15.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=fb5d854c-4996-4f1e-8c32-36ecc63d5acf rw quiet splash apparmor=1
security=apparmor udev.log_priority=3
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Portable System: Dell product: Inspiron 3442 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0C1F3F v: A06 serial: <superuser required> UEFI: Dell
v: A06 date: 01/12/2015
Memory:
System RAM: available: 7.67 GiB used: 2.72 GiB (35.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/2700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 13573
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid xsave xsaveopt xtopology xtpr
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mds mitigation: Clear CPU buffers; SMT vulnerable
Type: meltdown mitigation: PTI
Type: mmio_stale_data status: Unknown: No mitigations
Type: retbleed status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW,
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds mitigation: Microcode
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
620M/625M/630M/720M] vendor: Dell driver: N/A alternate: nouveau,
nvidia_drm, nvidia non-free: series: 390.xx+ status: legacy-active
(EOL~late 2022) arch: Fermi code: GF1xx process: 40/28nm built: 2010-16
pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 08:00.0
chip-ID: 10de:1140 class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4 chip-ID: 0bda:5756
class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0458 built: 2014 res: 1366x768
dpi: 112 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
GT2) direct-render: Yes
Audio:
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k5.15.109-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsactl,alsamixer,amixer
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl
Network:
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 06:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: dynamic noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: link
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
WAN IP: <filter>
Bluetooth:
Device-1: Qualcomm Atheros AR9462 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:7 chip-ID: 0cf3:0036
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 1.02 TiB used: 13.52 GiB (1.3%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0003 scheme: GPT
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 13.52 GiB (12.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fb5d854c-4996-4f1e-8c32-36ecc63d5acf
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: E2E1-8C2A
Swap:
Alert: No swap data was found.
Unmounted:
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: Arquivos
uuid: af8ff418-639c-498d-8bb7-caf48f9b2913
USB:
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
class-ID: 0900
Device-1: 1-1.3:3 info: 2.4G RF Keyboard & Mouse type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 276d:2068 class-ID: 0301
Device-2: 1-1.5:4 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5756 class-ID: 0e02 serial: <filter>
Device-3: 1-1.6:7 info: Qualcomm Atheros AR9462 Bluetooth type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0cf3:0036 class-ID: e001
Device-4: 1-1.8:6 info: Realtek RTS5129 Card Reader Controller
type: <vendor specific> driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
class-ID: 0900
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1d6b:0003
class-ID: 0900
Sensors:
System Temperatures: cpu: 54.0 C mobo: 53.0 C
Fan Speeds (RPM): cpu: 2610
Info:
Processes: 227 Uptime: 41m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1221 libs: 307 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
