Como executar programas via wine 64 corretamente
Esse é o erro que ocorre quando executo o mesmo pelo terminal pelo winex64… Pq esse programa so funciona em x64… Alguem sabe oq pode ser? Só falta ele p eu migrar totalmente pro linux… Agradeco a ajuda de todos!
Log de erro
000d:err:module:__wine_process_init L"C:\windows\system32\winemenubuilder.exe" not found
000b:err:wineboot:process_run_key Error running cmd L"C:\windows\system32\winemenubuilder.exe -a -r" (126).
0026:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0026:fixme:dwmapi:DwmIsCompositionEnabled 0000000006500434
0031:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x243306d, context 0x513660, init_notify 0, handle 0x72ff9c0): stub
0026:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0047:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0047:fixme:dwmapi:DwmIsCompositionEnabled 06A4DD14
0049:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x31cf537, context 0x2a3060, init_notify 0, handle 0x782fcd8): stub
0047:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
wine: configuration in L"/home/igor/.wine" has been updated.
wine: Unhandled page fault on execute access to 0000000140000000 at address 0000000140000000 (thread 0009), starting debugger…
005e:fixme:dbghelp:elf_search_auxv can’t find symbol in module
Unhandled exception: page fault on execute access to 0x140000000 in 64-bit code (0x0000000140000000).
Register dump:
rip:0000000140000000 rsp:000000000052fb38 rbp:000000000052ffd0 eflags:00010246 ( R- – I Z- -P- )
rax:0000000140000000 rbx:0000000000000000 rcx:00007fffffeaf000 rdx:0000000000000000
rsi:00007fffffea8000 rdi:0000000000000003 r8:000000000052f630 r9:0000000000000008 r10:0000000000000008
r11:0000000000000246 r12:0000000000000000 r13:0000000000000000 r14:0000000000000000 r15:0000000000000000
Stack dump:
0x000000000052fb38: 000000007b459602 00000200002b0000
0x000000000052fb48: ffffffffffffffff 0000000000000000
0x000000000052fb58: 0000000000000000 0000000140000000
0x000000000052fb68: 00007fffffeaf000 0000000000000000
0x000000000052fb78: 0000000000000000 ffffffffffffffff
0x000000000052fb88: 000000007b47b3f0 000000007b42f038
0x000000000052fb98: 000000000052ffd8 000000000052fb80
0x000000000052fba8: 0000000000000000 000000000052fb40
0x000000000052fbb8: 000000000052ffd0 000000007b6897e0
0x000000000052fbc8: 0000000000000003 0000000000000000
0x000000000052fbd8: 0000000000000000 0000000000000000
0x000000000052fbe8: 0000000000000000 000000007b45958a
Backtrace:
=>0 0x0000000140000000 in turbohud (+0x0) (0x000000000052ffd0)
1 0x000000007b459602 __wine_start_process+0x121() in kernel32 (0x000000000052ffd0)
0x0000000140000000: popq %r10
Modules:
Module Address Debug info Name (17 modules)
PE 7b000000- 7b2f5000 Deferred kernelbase
ELF 7b400000- 7b68a000 Dwarf kernel32
-PE 7b410000- 7b68a000 \ kernel32
ELF 7bc00000- 7beda000 Deferred ntdll
-PE 7bc20000- 7beda000 \ ntdll
ELF 7c000000- 7c004000 Deferred
PE 140000000- 1404c0000 Export turbohud
ELF 7f669e546000- 7f669e574000 Deferred libtinfo.so.5
ELF 7f669e574000- 7f669e59a000 Deferred libncurses.so.5
ELF 7f669f478000- 7f669f48c000 Deferred libnss_files.so.2
ELF 7f669f68c000- 7f669f6a7000 Deferred libgcc_s.so.1
ELF 7f669f6a7000- 7f669f7f6000 Deferred libm.so.6
ELF 7f669f7f8000- 7f669f7fe000 Deferred libdl.so.2
ELF 7f669f7fe000- 7f669f9f0000 Deferred libc.so.6
ELF 7f669f9f0000- 7f669fa13000 Deferred libpthread.so.0
ELF 7f669fa2a000- 7f669fdcc000 Dwarf libwine.so.1
ELF 7f669fdce000- 7f669fdfe000 Deferred ld-linux-x86-64.so.2
Threads:
process tid prio (all id:s are in hex)
00000008 (D) Z:\home\igor\Downloads\thd\TurboHUD.exe
00000009 0 <==
0000000e services.exe
00000021 0
0000001a 0
00000015 0
00000014 0
00000013 0
00000010 0
0000000f 0
00000011 plugplay.exe
00000017 0
00000016 0
00000012 0
00000018 winedevice.exe
0000001e 0
0000001d 0
0000001c 0
0000001b 0
00000019 0
0000001f winedevice.exe
00000024 0
00000023 0
00000022 0
00000020 0
00000027 explorer.exe
0000002f 0
0000002c 0
0000002b 0
00000028 0
System information:
Wine build: wine-5.0
Platform: x86_64
Version: Windows 10
Host system: Linux
Host version: 5.4.0-29-generic
Você não escreveu que programa é não é possível adivinhar né.
Da para colocar o Link do desenvolvedor do programa?
O Wine tem uma data base dos programas com formas de instalar e rodar:
As classificação é:
Platinum
Funciona tão bem quanto (ou melhor que) no Windows imediatamente.
Gold
Funciona tão bem quanto (ou melhor que) no Windows com soluções alternativas.
Silver
Funciona excelentemente para uso normal, mas tem alguns problemas para os quais não há soluções alternativas.
Bronze
Funciona, mas tem alguns problemas para uso normal.
Garbage
Os problemas são graves o suficiente para que não possam ser usados para a finalidade para a qual foram projetados.
https://wiki.winehq.org/AppDB_Rating_Definitions
Parece que se trata do TurboHUD, uma espécie de interface do Diablo 3. Creio que seja isso por causa desta linha:
Peço perdão, pensei que pelo codigo do terminal seria possivel ver de qual programa se trata.
