Buildar o aseprite
Então gurizada, estava eu belo, bonito e pimpão tentando buildar o software Aseprite, que é um programa que permite o usuario a fazer sprites em pixel, pixel arte, bastante coisa… Porém, eu não estou conseguindo, eles colocaram um tutorial lá de como buildar usando o ninja build e o cmake, porém, chega no final e dá erro. E eu acabei parando na hora de dar o comando ninja aseprite, dentro da pasta build. Deu esse erro gigante:
identar texto pré-formatado por 4 espaços
ninja aseprite ─╯
[239/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/getenv.c.o
In file included from /usr/include/x86_64-linux-gnu/sys/types.h:25,
from …/third_party/curl/include/curl/curlbuild.h:562,
from …/third_party/curl/lib/setup.h:120,
from …/third_party/curl/lib/getenv.c:23:
/usr/include/features.h:187:3: warning: #warning “_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE” [-Wcpp]
187 | # warning “_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE”
[241/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/telnet.c.o
from …/third_party/curl/lib/telnet.c:23:
[246/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/sendf.c.o
from …/third_party/curl/lib/sendf.c:23:
[247/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/if2ip.c.o
from …/third_party/curl/lib/if2ip.c:23:
[255/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/easy.c.o
from …/third_party/curl/lib/easy.c:23:
[256/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/cookie.c.o
from …/third_party/curl/lib/cookie.c:80:
[259/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/formdata.c.o
from …/third_party/curl/lib/formdata.c:104:
[262/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/mprintf.c.o
from …/third_party/curl/lib/mprintf.c:38:
[268/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/hash.c.o
from …/third_party/curl/lib/hash.c:23:
[274/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/transfer.c.o
from …/third_party/curl/lib/transfer.c:23:
[289/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/http.c.o
from …/third_party/curl/lib/http.c:23:
[304/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/nonblock.c.o
from …/third_party/curl/lib/nonblock.c:23:
[313/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/multi.c.o
from …/third_party/curl/lib/multi.c:23:
[346/1500] Building C object third_party/curl/lib/CMakeFiles/libcurl.dir/url.c.o
from …/third_party/curl/lib/url.c:25:
[608/1500] Building CXX object laf/base/CMakeFiles/laf-base.dir/fs.cpp.o
In file included from …/laf/base/fs.cpp:18:
…/laf/base/fs_unix.h: In function ‘std::string base::get_canonical_path(const string&)’:
…/laf/base/fs_unix.h:168:11: warning: ignoring return value of ‘char* realpath(const char*, char*)’, declared with attribute warn_unused_result [-Wunused-result]
168 | realpath(path.c_str(), buffer);
[830/1500] Building CXX object src/doc/CMakeFiles/doc-lib.dir/algorithm/rotate.cpp.o
In file included from …/src/doc/image_impl.h:19,
from …/src/doc/algorithm/rotate.cpp:16:
…/src/doc/image_iterator.h: In function ‘void doc::algorithm::ase_parallelogram_map_standard(doc::Image*, const doc::Image*, const doc::Image*, fixmath::fixed*, fixmath::fixed*)’:
…/src/doc/image_iterator.h:43:21: warning: ‘((void)(& delegate)+24).doc::ImageIteratorT<doc::RgbTraits, unsigned int*, unsigned int&>::m_image’ may be used uninitialized in this function [-Wmaybe-uninitialized]
43 | m_image(other.m_image),
…/src/doc/image_iterator.h:45:17: warning: ‘((void)& delegate +40)’ may be used uninitialized in this function [-Wmaybe-uninitialized]
45 | m_x(other.m_x),
…/src/doc/image_iterator.h:47:22: warning: ‘((void)& delegate +48)’ may be used uninitialized in this function [-Wmaybe-uninitialized]
47 | m_xbegin(other.m_xbegin),
…/src/doc/image_iterator.h:43:21: warning: ‘((void)(& delegate)+56).doc::ImageIteratorT<doc::RgbTraits, unsigned int*, unsigned int&>::m_image’ may be used uninitialized in this function [-Wmaybe-uninitialized]
…/src/doc/image_iterator.h:45:17: warning: ‘((void)& delegate +72)’ may be used uninitialized in this function [-Wmaybe-uninitialized]
…/src/doc/image_iterator.h:47:22: warning: ‘((void)& delegate +80)’ may be used uninitialized in this function [-Wmaybe-uninitialized]
…/src/doc/image_iterator.h:43:21: warning: ‘((void)(& delegate)+24).doc::ImageIteratorT<doc::GrayscaleTraits, short unsigned int*, short unsigned int&>::m_image’ may be used uninitialized in this function [-Wmaybe-uninitialized]
…/src/doc/image_iterator.h:43:21: warning: ‘((void)(& delegate)+56).doc::ImageIteratorT<doc::GrayscaleTraits, short unsigned int*, short unsigned int&>::m_image’ may be used uninitialized in this function [-Wmaybe-uninitialized]
[895/1500] Building CXX object src/tga/CMakeFiles/tga-lib.dir/encoder.cpp.o
…/src/tga/encoder.cpp: In instantiation of ‘void tga::Encoder::writeRleScanline(int, const tga::Image&, int, void (tga::Encoder::)(uint32_t)) [with T = unsigned char; uint32_t = unsigned int]’:
…/src/tga/encoder.cpp:93:64: required from here
…/src/tga/encoder.cpp:182:23: warning: unused variable ‘c2’ [-Wunused-variable]
182 | const color_t c2 = m_iterator.getPixel();
)(uint32_t)) [with T = unsigned int; uint32_t = unsigned int]’:
…/src/tga/encoder.cpp:138:80: required from here
[950/1500] Building CXX object src/ui/CMakeFiles/ui-lib.dir/view.cpp.o
…/src/ui/view.cpp: In member function ‘void ui::View::updateView(bool)’:
…/src/ui/view.cpp:182:15: warning: unused variable ‘child’ [-Wunused-variable]
182 | if (Widget* child = attachedWidget()) {
[1500/1500] Linking CXX executable bin/aseprite
FAILED: bin/aseprite
: && /usr/bin/c++ -Wall -Wno-switch -O2 -g -DNDEBUG src/CMakeFiles/aseprite.dir/main/main.cpp.o -o bin/aseprite lib/libapp-lib.a lib/libclip.a -lxcb -lpthread lib/libdio-lib.a lib/libfilters-lib.a lib/libflic-lib.a lib/libtga-lib.a lib/librender-lib.a lib/libdoc-lib.a lib/libfixmath-lib.a lib/libui-lib.a lib/liblaf-os.a lib/liblaf-gfx.a lib/liblaf-ft.a /home/mad/deps/skia/out/Release-x64/libskia.a /usr/lib/x86_64-linux-gnu/libGL.so /usr/lib/x86_64-linux-gnu/libfontconfig.so /usr/lib/x86_64-linux-gnu/libSM.so /usr/lib/x86_64-linux-gnu/libICE.so /usr/lib/x86_64-linux-gnu/libX11.so /usr/lib/x86_64-linux-gnu/libXext.so /usr/lib/x86_64-linux-gnu/libXcursor.so -lSKSHAPER_LIBRARY-NOTFOUND lib/libobs.a lib/libundo.a lib/libcmark.a lib/libjpeg.a lib/libgiflib.a lib/libwebpdemux.a lib/libwebpmux.a lib/libwebp.a -lpthread -lm lib/libfreetype.a lib/libharfbuzz.a lib/libfreetype.a lib/libharfbuzz.a lib/libpng16.a -lm lib/libjson11.a lib/libarchive.a /usr/lib/x86_64-linux-gnu/libexpat.so lib/libfmt.a lib/libtinyexpr.a lib/liblauxlib.a lib/liblua.a lib/liblualib.a lib/libupdater-lib.a lib/libcfg-lib.a lib/libver-lib.a lib/libtinyxml.a lib/libnet-lib.a lib/liblaf-base.a lib/libmodpbase64.a /usr/lib/x86_64-linux-gnu/libdl.so lib/libcurl.a lib/libz.a -ldl && :
/usr/bin/ld: cannot find -lSKSHAPER_LIBRARY-NOTFOUND
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
Fiz outro topico, fazendo uma pergunta mais simples:
Fecharei esse!
