Áudio do PC não funciona em compartilhamento de tela no Discord/Skype/Meet/Teams
Estou enfrentando problemas para compartilhar tela com áudio da placa interna do computador através do Linux. Quando estou no Windows eu consigo compartilhar a tela com áudio normalmente mas, no Linux simplesmente não funciona.
Instalei o Pulse Audio pra tentar resolver mas, não resolveu.
INFORMAÇÕES SOBRE HARDWARE E SOFTWARE:
System:
** Host: Lenovo Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc **
** v: 9.3.0 Desktop: Cinnamon 4.8.6 wm: muffin 4.8.1 dm: LightDM 1.30.0 **
** Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal **
Machine:
** Type: Laptop System: LENOVO product: 81FE v: Lenovo ideapad 330-15IKB **
** serial: PE04ECY0 Chassis: type: 10 v: Lenovo ideapad 330-15IKB **
** serial: PE04ECY0 **
** Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: PE04ECY0 UEFI: LENOVO **
** v: 8TCN60WW date: 11/26/2020 **
Battery:
** ID-1: BAT0 charge: 21.8 Wh condition: 22.9/30.0 Wh (76%) volts: 8.1/7.4 **
** model: LGC L16L2PB2 type: Li-poly serial: 40582 status: Unknown **
Memory:
** RAM: total: 11.61 GiB used: 2.01 GiB (17.3%) **
** Array-1: capacity: 32 GiB slots: 2 EC: None max module size: 16 GiB **
** note: est. **
** Device-1: ChannelA-DIMM0 size: 4 GiB speed: 2133 MT/s type: DDR4 **
** detail: synchronous unbuffered (unregistered) bus width: 64 bits **
** total: 64 bits manufacturer: SMART Brazil part-no: SMS4TDC3C0K0446SCG **
** serial: N/A **
** Device-2: ChannelB-DIMM0 size: 8 GiB speed: 2133 MT/s type: DDR4 **
** total: 64 bits manufacturer: 0000 part-no: N/A serial: N/A **
CPU:
** Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP **
** arch: Kaby Lake rev: A L1 cache: 256 KiB L2 cache: 6144 KiB **
** L3 cache: 6144 KiB bogomips: 28800 **
** Speed: 3400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3400 2: 3400 **
** 3: 3401 4: 3401 5: 3400 6: 3403 7: 3400 8: 3400 **
** Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon **
** art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid **
** cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c **
** flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp **
** hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca **
** mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat **
** pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts **
** rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 **
** sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust **
** tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt **
** xsaves xtopology xtpr **
Graphics:
** Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel **
** bus ID: 00:02.0 chip ID: 8086:5917 **
** Display: server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa **
** resolution: 1366x768~60Hz **
** OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.6 **
** direct render: Yes **
Audio:
** Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo **
** driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71 **
** Device-2: Intel USB PnP Sound Device type: USB **
** driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:3 chip ID: 8086:0808 **
** Sound Server: ALSA v: k5.4.0-65-generic **
Network:
** Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet **
** vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 01:00.0 **
** chip ID: 10ec:8168 **
** IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: 64:1c:67:a5:c3:ba **
** IP v4: 192.168.1.1/24 type: dynamic noprefixroute scope: global **
** broadcast: 192.168.1.255 **
** IP v6: fe80::3c0d:a968:8788:6d00/64 type: noprefixroute scope: link **
** Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi **
** v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:3166 **
** IF: wlp2s0 state: down mac: 64:32:a8:59:5b:f5 **
** WAN IP: 45.182.62.110 **
Drives:
** Local Storage: total: 931.51 GiB used: 23.75 GiB (2.5%) **
** ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-24Z10T0 **
** size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm **
** serial: WD-WXR1A681YZSA rev: 1A01 temp: 40 C scheme: GPT **
** Message: No Optical or Floppy data was found. **
RAID:
** Message: No RAID data was found. **
Partition:
** ID-1: / size: 915.40 GiB used: 23.74 GiB (2.6%) fs: ext4 dev: /dev/sda2 **
** label: N/A uuid: 613ae4d5-40d4-4790-be89-8912ed1c0ee4 **
** ID-2: /boot/efi size: 511.0 MiB used: 7.8 MiB (1.5%) fs: vfat **
** dev: /dev/sda1 label: N/A uuid: 1B57-3B91 **
Unmounted:
** Message: No unmounted partitions found. **
USB:
** Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 **
** speed: 480 Mb/s chip ID: 1d6b:0002 **
** Hub: 1-1:2 info: Unknown Manufacturer hub ports: 4 rev: 2.0 speed: 12 Mb/s **
** chip ID: 0a05:7211 **
** Device-1: 1-1.2:6 info: N/A type: Keyboard,HID driver: hid-generic,usbhid **
** interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 258a:002a **
** Device-2: 1-1.3:7 info: Sunplus Innovation USB PnP Sound Device **
** type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 **
** speed: 1.5 Mb/s chip ID: 1bcf:08a0 **
** Device-3: 1-3:3 info: Intel USB PnP Sound Device type: Audio,HID **
** driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 **
** speed: 12 Mb/s chip ID: 8086:0808 **
** Device-4: 1-7:4 info: Intel type: Bluetooth driver: btusb interfaces: 2 **
** rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2a **
** Device-5: 1-8:5 info: Acer EasyCamera type: Video driver: uvcvideo **
** interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:210f **
** Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s **
** chip ID: 1d6b:0003 **
Sensors:
** System Temperatures: cpu: 48.5 C mobo: N/A **
** Fan Speeds (RPM): N/A **
Info:
** Processes: 282 Uptime: 19m Init: systemd v: 245 runlevel: 5 Compilers: **
** gcc: 9.3.0 alt: 9 Shell: bash (sudo) v: 5.0.17 running in: gnome-terminal **
** inxi: 3.0.38**
Estou migrando totalmente para o Linux mas, este é um recurso que preciso funcionando.
OBS: Os dispositivos são reconhecidos mas, apresenta a seguinte mensagem da imagem ao realizar o compartilhamento "O áudio pode não estar disponível ao compartilhar a tela do seu dispositivo "
Espero que consigam me ajudar e, desde já agradeço!!!
Olá @Jair_Souza seja bem-vindo ao Diolinux Plus :wave:t2:
No Nemo, o gerenciador de arquivos, pede para mostrar “pastas ocultas” então vai aparecer uma pasta .config. Dentro dela irá ter a pasta pulse. Deleta ela.
Feito isso, no terminal digita o comando pulseaudio -k enter e reinicia o computador. Faz os testes para ver se volta a funcionar.
:pray:t2:
Obrigado pelo resposta @RuKsu!!!
Eu fiz o procedimento mas, o próprio sistema adiciona novamente a pasta no diretório. Infelizmente não consegui utilizar o áudio nas transmissões nos Apps.
Obs: O nemo, ao inicializar o sistema novamente após o procedimento, solicita acesso de administrados para realizar alterações no sistema. Acredito que seja isso que adiciona a pasta novamente.
Desde já agradeço!!
Certo. Bom esse procedimento é um “reset” na estrutura do Pulse, ele vai ser reconstruído denovo mas, “novinho em folha”. Isso serve para limpar configurações que poderiam estar causando problemas. As vezes acontece de um programa escreve dados, depois vem outro e rescreve daí quando o primeiro vai usar, falha… É como limpar os cookies e cache de um navegador. Como não resolveu este procedimento então é outro detalhe. Estou pesquisando por resoluções.
